Root issues with lg connect after unrooting.
tonylc74
Hi, my problem occurred after deleting xbin folder, su, and then superuser APk from system/app. This was fine till I did a hard reset, afterwards when then phone did finally reboot, when I was doing the device setup I had no keyboard to enter my gmail account and other info. Well it got worse. The phone would force close and a dialogue would come up saying: android process settings have shutdown unexpectedly. The only way I could fix this was to first, use my wife's phone to send me a text with a link for a keyboard apk. Then I had to do the same for a launcher/home replacement because it wouldn't load my homescreen either! What would be you're thoughts on this? Sorry about the long post but I thought this could help if anyone else experiences this problem.
Did you uninstall/delete either one of those, the home lg launcher or the lg and or the Swype keyboard while you were rooted?
No I had them frozen with antek app manager, so I'm thinking maybe they remained frozen after I unrooted. I'm afraid to shutdown my phone in fear of it not rebooting correctly.
its possible. as a rule of thumb its bad to remove home and keyboards. you might need to do the soft restore
Kanaida how do u do a soft restore? Even if I don't its all good I'm getting a replacement Thursday or Friday. But would still like to know how.
And yea I know you don't remove home/keyboard, I had keyboard frozen because it kept wanting to come on. Their still in system/app but I'm not rooted now so I can't access.
ok where do i need to read so i can learn to unroot this thing. im used to odin. is there another method i dont know about??
If u know already then disregard. Go into system/app and delete xbin folder and cwm then delete or move superuser apk, if I'm wrong then Simone please correct me.
I have ur info uploadfromtaptalk1405395093256.jpguploadfromtaptalk1405395141876.jpguploadfromtaptalk1405395164584.jpg
Sent from my SM-S765C using Xparent BlueTapatalk 2
