ITT: Post your Captivate's battery life
batt level: 41%
batt use: 81 h, 19 min, 54 secs since unplugged
with:
cell standby 34%
Phone Idle 52%
display 11%
wi-fi 2%
Android system 1%
edit: Not rooted, no fancy battery apps or task killing stuff, but i do have a the static black and white dots wallpaper and use wifi when available
:(11h 27m unplugged
Battery level: 47%
Cell Standby: 48%
Display: 21%
Phone idle: 15%
Voice calls: 7%
ESPN: 4%
Android System: 2%
Android OS: 2%
Anyone have any ideas why my Cell Standby is eating the life out of my battery?
LOCATION LOCATION LOCATION! Your in an area with bad reception and your phone is working harder to get a signal. Nothing you can do about that unless you wanna spend mad $$$ on a signal booster everywhere you stay at...which is pointless.
________________________________________________________
Anyways I HAVE A REQUEST FOR EVERYONE!!!!!!!!!!!!!!!!!!
^^^Hope that caught your attention
Can everyone post your time of use along with the percentage of the display, voice calls, and media server(music)? This will really show everyone how much the phone was used.
here go my stats:
10h 42m
76%
Display 41% **1h 7m <- i consider that light usage btw
Cell Standby 22%
Phone Idle 15%
Mediaserver 7% **20m 41s
Voice Calls 5% **1m 14s
Android System 4%
Android Os 2%
*****Wifi 2% 7h 35m 28s***** Thats why the phone should use wifi instead of 3g
btw sorry about the long post
here go my stats:
10h 42m
Cell Standby 22%
Phone Idle 15%
Android System 4%
Android Os 2%
What was/is your corresponding overall battery percentage???
Unplugged 16h 50m 42s (lol)
Percentage left of total battery - 30%
Display - 34% 1h 10m
Cell Standby - 24%
Phone Idle - 17%
Voice Calls - 9% 5m 6s
Sensorserver_ya - 5% (what the heck is this?) 18m 3s
Mediaserver - 3% 12m 6s
Android System - 3%
Antivirus - 3%12m
Compass - 2% used gps for 3m
Android OS - 2%
Battery Level: 76%
9h 32m 52s since unplugged.
Display: 38%
Voice Calls: 23%
Cell Standby: 20%
Phone Idle: 14%
Android System: 2%
Browser: 2%
GPS: OFF
Display Brightness: looks like @ 25% (auto adjust off)
Bluetooth: OFF
Wi-Fi: OFF
3G: on
I keep most apps "task-killed", except Email, Clock, Music Player, Messaging. Sometimes I close out Music Player.
Note: Used a little bit so far today, just for voice calls and email checking. Perused some Facebook. Did a tad of internet browsing.
I have only had the phone for one week. I definitely have seen my battery life improve after a few power cycles. :D Went two days without a charge ending yesterday, I did a lot of browsing, facebooking, and played SNESoid quite a bit the night before. I was shocked it lasted so long. Wish I had recorded the stats then. :)
1st post, thought this would be a good one to jump into.
My batt level: 29%
batt use: 22 h, 27 min, 27 secs since unplugged
with:
display 43%
cell standby 16%
idle 10%
voice calls 22%
android system 2%
Mix of using wi-fi and not. Brightness turned all the way down, auto adjust off. Most Internet access is done over wi-fi
it says 4 hours cause my phone got stuck so i had to reset it
What is the battery status app your using?
Mine only last for 7hrs and I can't even turn on the phone. down to 5% trying for the past 7 days same result. Reset phone, flash stock firmware etc.. same thing
I read from other forum some battery life suck and others were good so I just bought another samsung G9 with diff date etc.. to try it out
Battery level = 63%
Unplugged for 9h 51m
Voice Calls = 49%
Display = 26%
Cell standby = 13%
Phone idle = 8%
Android Sys = 2%
Some web browsing on cell network, mostly on wifi, display brightness all the way down, GPS stays off unless I update Loopt or use GMaps. I usually get at least 2 days out of mine. Less if I play alot of PSX4droid.
75%
15h 36m 30s since unplugged
Cell standby - 34%
Display - 31%
Phone Idle - 25%
Voice Calls - 6%
Android System - 2%
Galaxy Domination - 2%
Couple short calls, checking emails as they come in, 10 or so text messages.. couple rounds of games (Galaxy Domination).. fairly light on the usage today. I'm normally around 60 to 50% at this point of night.
Wow. I want that. I'll have to checkout lookout and 3g watchdog. Although I think I'll keep brightness set to auto because when you're in direct sunlight it changes to a brightness that makes it MUCH easier to see; it will go from barely viewable to comfortably viewable. From the looks of it though you didn't really use your phone...like at all. So...did you use your phone at all or did it just sit in your pocket auto-syncing every-so-often??
I didn't charge last night and put it up for charge for about 15-20 mins before leaving this morning. I'm at 87% now
3hrs 8m since unplugged.
For brightness I just swipe to the right along the top bar to max out brightness outside.
I'm at work most of the time and get home and play games on it at night basically. Don't use at a whole lot, but I did make about 1hr worth of calls yesterday.
My wi-fi is set to turn off when idle or unavailable and i have 0% time without signal.
Are you doing this from the home screen? If so is it an app or native? Sounds way cool and I'd like that better than the widget button apps. Thanks! :)
you have to have auto-brightness off and then you can just swipe the status bar left and right to adjust brightness pretty much any time the status bar is visible (wont work when in camera mode)
Yes please! this would help a lot.
63% at 9h 0m 19s since unplug
Display 45% - 53m
Standby 21%
Idle 14%
Mediaserver 6% - 15m
I reallt think I have a dud!
9h47m off charger
Put back on charger at 12% to get through rest of day
Display 40%
Voice 35%
Cell Stby 7%
An Sys 6%
Market 6%
Idle 4%
And OS 2%
Swype 2%
I talked for about 25 minutes
sent/received about 60 texts total
looked at 3 apps on 3g, no downloads
Normally- 3g toggled off, no wifi, no gps, lowest screen brightness, always switch to standby, black backround, no background data, task killer
Everything I could possibly do without messing with the ROMs/rooting.
Bad battery? I talked to AT&T store and they offered to switch out battery. Is it the battery or the entire phone itself that causes the drain?
Thanks for any replies....I have 10 days to decide.
battery remaining: 14%
time since last charge: 123 hours 17 minutes 31 seconds
Phone idle - 43%
cell standby - 37%
voice calls - 11%
display - 9%
how long was ur display on for?
over the course of 6 days, i don't really know, but probably on average 1 - 1.5 hours per day for web browsing and time/weather checking and reading push email, so maybe 6 or 8 hours total? I dont know how to find the exact time...
You click on the display heading while in battery use, you can do that for all of the headings and it will give you more detail.
well if that estimate is correct, then i must have a defective battery or something. i can probably only get 2-3 hours of use from my phone and be unplugged for like 15 hours max.
No one else can achieve this kind of battery life. His phone must have super powers. Maybe his can teach ours?
