ok, it is actually 6 full days, even more
you saw that the battery level was 33%
I rooted my phone in case to use the titanium backup. I used the titanium_backup to remove the nonremovable AT&T applications, since I'm in Bulgaria and I don't need any AT&T features. But it is not the important thing. I installed the "CPU Tuner" and modified all of the profiles available in that good software.
!!!! NEVER USE "Extreme power save" !!!
Otherwise the phone will stop and the only way is to replug the battery, I think it is a bug in the CPU-Tuner software.
1. Uncheck the "Power saving mode" from the main options of the phone
2. Uncheck the Sync from the phone options
3. type *#2263# and select GSM ... option 3
4. select GSM all
5. type *#0011# to check if the GSM net is in use
p.p. you have to do that (3,4,5) after each reboot ... the phone doesn't remember that. It is not a problem, because I don't see a reason to reboot the phone often, so if you use it normally this network option is active till restart of the phone or replug the battery
6. Keep WiFi and GPS off
7. remove any animated wallpaper and use a black static wallpaper (it sounds strange, but it is AMOLED display)
I didn't find differences with BT OFF and ON, seems the BT drains very small current from the battery ...
till now, ok ...
let me tell you my settings of the CPU-Tuner ...
5 triggers:
1. Battery full - 100%, Performance, Screen Off, Performance, Performance
2. Battery used - 80%, Performance, Screen Off, Performance, Performance
3. Battery halfl - 60%, Good, Screen Off, Performance, Good
4. Battery lowl - 40%, Normal, Screen Off, Performance, Normal
5. Battery critical - 25%, Powersave, Screen Off, Performance, Normal
Profiles:
Performance: Full Speed, 100-1000 MHz, all unchanged
Good: Full Speed, 100-1000 MHz, all unchanged
Normal: Normal, 100-1000 MHz, all unchanged
Screen Off: Save Battery, 100-1000mHz, MD and WIFI are off. all others are unchanged
Powersave: Save Battery, 100-1000MHz, all unchanged
Extreme powersave ... never mind, since we don't use it
Also ... I have installed Android assistant, and Advanced task killer. After reboot the phone and after voice call I start once the Advanced task killer and kill all processes .... I'm not sure it makes the battery life longer. ... will test next week without this action after every voice call.
p.p. I use Loader (ginger one) ... downloaded from the market.
also ... I found something strange ... if I unplug the charger from the phone when it "decided" that the battery is 100% charged ... sometimes it deads. I tried some methods, but they eats the battery. My experience shown me that if I leave the power(charger) plugged even it said it is charged - all is ok, the battery is really 100% and the phone DOESN'T DIE RANDOMLY !!!
Actually ... last month I attach the phone to the charger evening time and unplug the charged in the morning and ... all is OK. I do that every 5-6 days
Let me share that I tried to overclock the CPU to 1.3 GHz ... all was fine.
My phone also is lag-fixed ... if it is important ... I'm not sure, think no ...
Please, let me know if the info I posted here is good for you guys!
Thanks in advance !
Jethro
p.p. Is there someone which already has made its Cappy to work with gingerbread 2.3.x ?
if yes, please tell me how (step by step) and give me the URLs to download the needed things.
A lot of thanks in advance !!!
