born_fisherman
Member
For more detailed instructions (how I did it) see post #24
_______________
For those of you that have not been able to successfully upgrade to the OTA update released this week, download Kies version 1.5.3 (latest version)
http://down.kr.samsungmobile.com/uploadimg/service/support/download/anycall/sw/Samsung%20KiesSetup.exe
Easiest way for me to do this was to uninstall the current version of Kies - For some reason the update (when you open Kies you will be prompted that an update is available (to 1.5.3)) would not install fully
Once your phone is recognized, it will say a firmware upgrade is available - follow the prompts and enjoy your upgrade firmware! Make sure your battery is near fully charged or you may get a message saying to charge before it can update.
My phone was unable to communicate to the AT&T servers to download the ota updates - I am now successfully upgraded to JH7!
Also, the LBS menu is not available by pressing the usual number sequence - use LauncherPro and create an Activities shortcut - delete GPS data before you do your first GPS test.
btw- I am not responsible for anything bad that may occur
_______________
