MiniKies crashes every time phone is plugged in
I gave up on Mini Kies - after two hours of troubleshooting I reinstalled Kies 1.5.3 - it works for me every time I plug the phone in.. not sure why there is so many issues with this software..
Well I removed Superuser (root) and BusyBox and reverted to my backup copy of settings.db. I then did a factory reset - trying to get my phone back to as close to stock as possible. When I click "Firmware Upgrade" I get a message that says "The device does not support Firmware Upgrade"
Any ideas why? Even after all this I still can't get the OTA update to work.
Nope - just rooted and sideloaded so I could get the SiriusXM app installed.Are you running a custom ROM?
Same here.Im running Kies on Windows 7 64bit. Works for me.
Regards
Steve
Question
I connected my new Samsung I897 to my computer using KIES and and it asked for up grade, I opted for it and later a message appeared upgrade failed and restart yr phone.
Phone did not boot up, since than I am trying to use Emergency recovery as by pressing both volume buttons and connecting USB cabel. But every time phone only swith on with computer icon appear on phone. Please help
@ born_fisherman
please let me know how you did it..i have the samsung kies 1.5.3 but i receive that "MSC.Thunder.Firmwareupdate has stopped working" error message. i appreciate any help that you can provide
i cant even get kies to run. it shows up in the taskbar but when i try to open it i get this:
FATAL ERROR:
Exception has been thrown by the target of an invocation. Error at object 'label1' in markup file
'MSC.Thunder.UI;component/controls/exceptionpopup.xaml'.
its really frustrating cuz i would like to get it working
running windows XP
I just got the phone should I install this program and update?
