saintdanbert
JuiceDefender does a great job of managing wifi vs. 3G vs. battery use.
However, I have what feels like a problem.
I go into some place where there are lots of strong and secure wifi sites -- secure meaning I cannot use them at all. Next, I try to do some phone-data operation (check email, browse web, etc) and "nothing happens." Specifically, the 3G activity icon does not appear. Some data apps will complain saying, "you must be connected ..." but that is not true for all data apps.
Do I have a program bug with JuiceDefender, a setting issue with JuiceDefender, some other issue with a loose end-user nut, or is something else going on?
Merci d'avance,
~~~ 0;-Dan
Merci d'avance,
~~~ 0;-Dan
