exzacklyright
1) So by flashing:
http://adrynalyne.us/files/kernels/DI01package3.tar.md5
It returns you to stock / unrooted?
2) Fastest way to get to EB01 from a un-rooted stock phone?
Would it be to flash EB01 MODEM, and then put
http://dl.dropbox.com/u/7223192/RootSF/su-2.3.6.1+busybox1.19.zip
and the update.zip on your sdcard and then just use odin to flash the new cwm (red) ? And then use that to flash EB01?
I'm open to suggestions. It just seems like a lot of the threads are out of date. The hardest part is the rooting / installing cwm. I'm just wondering if there's some quick way.Thx
I'm thinking about doing it for a friend though. That's why I ask! So is my method good? I edited the OP too
