Just one Question. LED comparison to EVO 4G
dequardo
How does the LED light compare to the EVO 4G. Size-wise and brightness/viewablility? Is it a pinpoint like the Thunderbolt's or more like the OG EVO?!
THANKS!
Mike
Evo 3D LED Notifier:
Green (Thanks Engadget):
Red (Thanks Doomstang):
I like having LEDs on my phone again. I have one on my Blackberry Curve, which I finally retired a few months ago. I had a Samsung Intercept for a few months, and now I got into this monster that is the EVO 3D and I love it. My only gripe with the phone and LEDs is that I want to use different colors for different notifications, and can't for the life of me figure out how to do it. This is my first Sense device, so I'm pretty nooby about it. Any help would be great.
Do they put LED notification lights on top of the phone or just the front? Would like to look down at the phone to see if I have messages instead of the front of the phone.
I know the LED can produce Green and Red, but I was wondering if anyone else has found out if those are the only colors it can produce due to hardware limitations, or if it can do more. It should be able to do Amber Yellow by combining the Red and Green. I wish it could do blue, it would go with my theme and it looks good on the phone.
With a tip of the topper to Roze, try Light Flow Lite and see if that gets you closer to the answer.
Might require root, so you have to let us know if it helps.
Tried Light Flow and couldn't get it to do other light colors, I don't have my phone rooted and I didn't change all the settings fully though
Whoa, i tried light flow but it makes the green led flash uncontrollably. sometimes its solid, sometimes it's solid, sometime's it blinks just a little.
I would like if it works!
You have a green and red LED. The only color you can make with those is yellow. If there's no way to turn them on simultaneously, the only way to simulate yellow is to alternate red and green really fast.
Sounds like the app is trying to do that but is failing to activate the red light. That might explain the green flashing.
I remember those days when the high for the day was only 91.
But for the LED: I would have liked a blue LED option, but really all I want to do is make it so charging doesn't take control of the LED. So that light flow app looks like it'd be very useful once we get perma-root / S-Off.
Coming from a Sprint HTC Hero, the LED on the Sprint HTC EVO 3D seems a bit dim in comparison, but I like the choice of red and the rich green color. The LED on my Sprint HTC Hero could light up the room at night with the orange or green color.
My wife's Sprint HTC EVO 4G seems about on par with the Sprint HTC EVO 3D in terms of the LED brightness, but the green color is slightly different. I like that they are hidden behind the mesh of the earpiece grille.
if they only included a blue LED... then you can make pretty much any color you want, since all of the primary light colors are represented.
how did you get blue led'?
I think it was either the lighting conditions or a Photoshop job. Those LEDs are not blue on the Sprint HTC EVO 3D. :)
Sometimes darker surroundings can cause a color shift to blue. I guess the other explanation could be a set of modified LEDs, but I am leaning towards the more practical reasons that I outlined above. ;)
did anyone else notice the led across the notification one?is tht like a front facing cam flash?
I think that might be a light sensor you are seeing. It adjusts your background brightness for you if you have it set on automatic.
no its in the mesh across from the notifier,its right next to the ambient light sensor but within the mesh,ik wat ur tlking about but its most deff not it less im wrong and the one in the mes is the sensor and the one on the outside of the mesh on the left side is really just a flash for the front facing cam,does the front facing cam have its own flash?
I see what you are talking about. When I shine a flashlight on the mesh part I can definitely see it. It's kind of shiny with a yellow hue to it.
Haven't a clue what that is...:confused:
It's shiny coppery/amber colored and roughly square looking (although the cut out in the frame is circular). I'd say it is a sensor of some sort and unfortunately not a usable LED. Someone that has the FCC Schematic saved can probably find and verify the part number unless it was a last minute addition to Revision 2. I forgot to save that file way back when it was news and it has since been taken down.
Check out this video (it is the best thing we have to go on so far).
Skip to around 4:45 and for Pete's sake, make sure you mute your speakers!
MUTE ME...PLEASE!!!!!!
I was wondering what that was for too. And is the clear circle to its left the light sensor or is that a flash? my front camera mode says it has no flash.
And I like a lot of weird music, but holy wow that is loud and bad
Those pics aren't mine, they came from someone who modified his 3D to have blue leds
