[K2_CL JB] Official OTA - Modded Zip for your flashing pleasure
  • Start date Start date
Status
Not open for further replies.
Can anyone confirm that visual voice mail works? I don't get the icon any longer, and when I try to update the app, or send a message I get server connection errors.
Thanks in advance.
Same here Heloguy!!! visual voice mail is not connecting. :(
Anyone else with this problem??? :confused:
Thanks Guspeed. I was starting to think i was the only one. I have been trying everything for the last 2 days. multiple backups from Titanium, Etc. hopefully Simon can figure this out after a much needed break.
Mine isn't working either. However did before on the stock rom.
Sent from my C525c using Tapatalk 2
Yeah a lot of stuff like that's broken... Which is odd. Can someone who's totally unmodified stock soff and flash this ota and give me the system backup after flashing jellybean. If your soff your safe
this phone wont overclock past 1.7ghz it wont handle anything higher then that, and even at 1.7ghz it doesn't really overheat. i set all my kernels to default to factory speeds so if you want to overclock you have to do it manually every time. even if you have an init.d script my kernels override those settings and default's back to 1.1ghz on reboot.
I keep having this issue where everytime I reboot my phone, it'll keep saying that android is upgrading. Is anyone else having that issue?
I've noticed the home, option and back buttons don't vibrate when you press them is that normal for Jellybean?
You don't have power saver on right? Turning that on disables those button vibrations.
Edit: wow I'm slow. Thought I was already on last page of the thread lol!
Yeah I had it on to save battery, got 21 hours on one charge.
I'm not sure if it's an s off thing or the jb rom, but has anyone else noticed that if you go to settings/about phone/HTC error reporting/ it says that this is a test device and error reporting can not be turned off regardless of settings? I googled s off htc error reporting but didn't find any connection to it.
I'm pretty sure that is because of s off
Hi Simon. I was wondering if anyone who was stock ota sent you a backup so you can look into this?
I need a totally unmodified ics user. No zips removed. No deodex. No root. Your totally stock. I need them to also have the stock recovery and be soff. Once soff get the ota from settings and flash it. You can then flash twrp and give me the system backup
Status
