[K2_CL JB] Official OTA - Modded Zip for your flashing pleasure
  • Start date Start date
Status
Not open for further replies.
Simon,
I flashed it and the only thing not working is what you already know about so far Everything else is working fine including wifi. Nice work and thank again.
I'll continue to test it. Getting ready to try all bluetooth functions. Headset, file transfer, etc. I'll let you know in a few if I have any problems.
Hi Simon,
Everything is working fine for me except the same issue with Bluetooth calling remains. Thank you so much for all off your hard work!
Goo.im Downloads - Downloading anykernel-SickKernelv10-4.1.2-071813.zip
This one works. Enjoy guys. if you want to enable s2w in terminal emulator do
echo "1" > /sys/android_touch/sweep2wake
echo "BACK" > /sys/android_touch/sweep2wake_startbutton
echo "MENU" > /sys/android_touch/sweep2wake_endbutton
eventually I may just set it to be enabled automatically
When I type echo "1" > /sys/android_touch/sweep2wake I get
sh: can't create /sys/android_touch/sweep2wake: No such file or directory
What am I doing wrong?
Edit: I opened up /sys/android_touch/sweep2wake in file explorer and sweep2wake isn't in the folder.
Hey bro, clean out your PM box. It's full. Lol. :D
can you please do the following for me on your phone,
1) Root
2) install terminal emulator
3) Install busybox
4) open terminal emulator and follow below steps
4a) type "dd if=/dev/block/mmcblk0p35 of=/sdcard2/system.img"
4b) type "dd if=/dev/block/mmcblk0p20 of=/sdcard2/boot.img"
5) Upload these two files (zipped will make it a bit smaller) to dropbox or wherever
this will allow me to fix a lot of the odds and ends :)
Anyone yet? If not I can in a couple hours.
Sent from my C525c using Tapatalk 2
I found a small problem, I don't know if its a bug or not but everytime I reboot I have to pick Perfect Keyboard Pro again. The changes won't stick.
WARNING: I NOR ANYONE EXCEPT FOR YOURSELF ARE RESPONSIBLE FOR ANYTHING THAT HAPPENS TO YOUR PHONE. THIS IS ESPECIALLY TRUE IF YOU DO NOT FOLLOW DIRECTIONS. IF YOU DO NOT UNDERSTAND ANY PART OF THIS THREAD, ASK!
Okay so now to the instructions.
S-OFF
Install TWRP OR CWM
Download the rom.
Download wiper fix.
Factory reset.
Flash rom.
Flash wiper fix.
reboot phone.
Enjoy.
If your not S-OFF this rom wont work. Sorry, but you'll have to do it.
I flash the ROM and get E:Error in /sdcard/BOOST_htc-k2_cl-jellybeanOTA4_1_2-20130712-simon.zip
(Status 0)
Installation aborted.
Any ideas? I performed a factory reset.
My first attempt gave me an error like that. Went back and looked at the file size and discovered I had a bad download. Was only 350+ MB instead of 500ish in the zip file
(Status 0)
Are you s-off and have you used the stable clockworkmod?
:eek: Wow, I just noticed the reply and everything and I saw for some reason someone typed in some trash. It wasn't me. My friend hacked into my phone and started talking trash. Sorry Simon Simmons. Don't take this out for irrelevancy. I want everyone to see this. I haven't been on due to time constraints
So did voicemail get fixed?
Check out this thread: The Ultimate Guide: S-Off, Recovery, Root, & Jelly Bean. Download the nandroid and restore it. It should give you a totally stock version of Jelly Bean with everything working. All credits Heloguy.
If you're worried about having to re-restore your apps, do this: Before you restore that nandroid that you downloaded, make a complete backup of your phone. Then, after that, restore the nandroid and then do an advance restore of the backup that you previously created and just restore the data. I did that and it works.
Make sure you are running CWM too because the backup you need to flash is a CWM backup and will not flash with TWRP. ;)
  • Like
Reactions: i2f
Status
