[K2_CL JB] Official OTA - Modded Zip for your flashing pleasure
  • Start date Start date
Status
Not open for further replies.
WARNING: I NOR ANYONE EXCEPT FOR YOURSELF ARE RESPONSIBLE FOR ANYTHING THAT HAPPENS TO YOUR PHONE. THIS IS ESPECIALLY TRUE IF YOU DO NOT FOLLOW DIRECTIONS. IF YOU DO NOT UNDERSTAND ANY PART OF THIS THREAD, ASK!
Okay so now to the instructions.
S-OFF
Install TWRP OR CWM
Download the rom.
Download wiper fix.
Factory reset.
Flash rom.
Flash wiper fix.
reboot phone.
Enjoy.
If your not S-OFF this rom wont work. Sorry, but you'll have to do it.
Found this JB to be a bit buggy:
1) I frequently cannot paste from my clipboard. Long press in a field frequently does not show the paste option.
2) Loved the battery life of the HTC One SV, but now it drains much more quickly.​
:confused:
:confused:
I don't have any problems with my clipboard and there's a battery saver option built into jb.
Sent from my C525c using Tapatalk 2
sys it won't work without s off. what is s off ? how do I know if I am s off already?
I got an already roode ICS one SV. i borked it installed font installer (clearly it did not like that) no about of wiping and resetting in CWM would make it boot up.
is s off part of root so if I am rooted I am already done s off? can I do s off without booting the phone? ie from CWM ?
If you power off your phone and boot into the bootloader it will say s-on or s-off. If you want info about s-off you should check out the moonshine thread.
Hello guys. I wanted to tell you all if you haven't already flashed this, please do not. It is broken in a few ways, due to the way the update was applied. I have managed to fix it locally. I'm going to deodex it and fix stuff up for proper flashing sometime today hopefully, however I may not be able to. I am working on getting sense 5 ported over.
Thank you very much! I prefer your ROM to the latest stock update!
Everything works, except the FM Radio. It looks like the radio tunes in and locks station frequencies, but there is no audio output. Audio works fine in other apps.
Thanks again!
Thanks again!
That's because I didn't have good kernel sources. Flash my new kernel :)
I had a rooted jelly bean through cwm, I was rooted with s off through moonshine I used cwm recovery to flash your Rom, I cleared everything applied your sys fix and now I can't gain root access please help
if you flashed superSU through CWM, that's the problem.
thus ROM has superuser by koush already in it
so after flashing Another superuser, a.k.a. superSU, now there are 2 system apps with 2 different su binaries that cancel each other out
to fix the issue
wipe the system
wipe data
wipe cache
wipe dalvick
reflash the ROM
reflash symlink
reboot
I have done all that already however im doing it through my phone using the clockword mod recovery do I have to do it through adb and if so how also looking at super su on the market it apeears to be having problems with latest update
Why not just update to 4.1.2 via OTA?
!#EDIT#
make sure NOT to flash any superuser because this ROM is pre-rooted with Koush's superuser
ok so i have the new kernel(v20) and voicemail is working great thanks simon for that patch, i cannot stay rooted though i completley wiped my phone to the point i thought i had bricked it after i redownloaded your boost file i applied using zip from sd card on cwm recovery through phone, then i applied your symlink the way then fixed premissions when i rebooted it it showed the su request in the ntification bar i tapped on it it said the binaries were out of date i tried installing it using the cwm method it went into recovery then gave me a meesage over signature couldnt be verified and the blue status bar stopped about a quarter of the way i let it sit for an hour no change then i went ahead and selected install untrusted zip it stopped at instaling binaries i had to reboot then no root access so i reflashed your zip files again same way then instead of hitting install through cwm i chose install it worked untiul the phone powered off now i cant get root to work at all also if i flash the zip file again do i need to reflash the v20 kmernel
ok so it says this
e: signature verificatiion failed
installing update...
installing superuser...
installing armeabi binaries
then stops and displays the boot methods
this is if i select update through cwm
ok so it says this
try using TWRP and when binaries need updating just click normal way.
they'll install just fine with out booting into recovery to do it
After many reflash and reboots I got it figured out I had to download the boost file from Simons, to my desktop removed his superuser.apk and installed with a supersu.apk put phone into recovery used install using sideload installed that plus symlink fix, after reboot everything worked great, I did have to reflash the v20 kernel again. I don't know if it was the superuser.apk inside that file, or the cwm that was making it screwy hopefully this can help someone else with the same issue I do still have a copy of it as well
Couldn't you just have installed supersu through play store? That's what I've done. In its settings is an option to remove the other super user app.
Status
