Help Keeping my phone awake
Check in Settings -> Applications -> Development -> Stay awake when charging... If this is turned on then the phone will say lit other than that, I'd need more info.. hope this helps!
Actually I think its an app. It does it when the app gives me a notification or running. I have too see. Thank you guys! Really helpful :D
Yeah if you reflashed everything then it HAS to be an app that is doing it.
Do you have an battery saving apps or anything like that? Check these settings in those.
