Keeps Freezing
DasXero
My Samsung Galaxy Prevail is a little over a week old, and after 3-4 days of having it I had rooted it, and put Shabbymod 0.9-Loaded on it, than I did a Factory Restore, as recommended. But during the little time it was unrooted, it frooze too, but infrequently. Now it has gotten to the point where whenever I want to use it again I have to pull the battery.
What happens is I press the power button, the screen flashes on, but the touch screen doesn't work. My Live Wallpaper still moves, etc. But I can't touch anything.
Also I have woken up to my phone shut off when I had kept it on, idk if that is relevant or not.
honestly sounds like a hardware problem, but I dont know, you could use odin and put factory unrooted and take it back, see if it is hardware defect.
I was gonna go back restore it back unrooted with Odin, than do a factory reset, than format the sd card, root it, than put Shabbymod 0.9 back on, do another factory reset, and another sd card format. See if that helps at all.
