ggt1_02
Like the title states I am seeking some advice on selecting a kernel, currently I am running adrynalyne's Super Clean .4 for DL09 and DJ05_Dl09 kernel. The only reason I am running this kernel is to keep clockwork. I am looking for improved battery life, and not quite ready to venture in to Voodoo land. All I am looking for is a something UV and non-Voodoo. I was looking at geekniks stupidfast is this even compatible with dl09?
1. Being that I am running superclean does this limit my choices?
2. Are all kernels installed the same way?
3. If I change my mind and want to start over with a new ROM, kernel, etc., is there a certain order or process to do this?
Thanks in advance.
Thanks in advance.
its really simple for the most part you really don't need luck. Flashes all the same. Just listen for voices
