Root kernel and random reboots
Dark2456
Well I'm back, have another problem. I've sorted out what rom I'd like to use, but I've come across a problem. I'm running they energy 1.5.2012 rom with anthrax kernel, but some times my phone will just freeze and then go to the boot image and loop. I think It's the kernel becaue it does it on all roms I use.
ITT: what is a decent kernel to use with this rom
Come to think of it I think it was doing on the freedom kernel too... Do you think maybe its because my phone doesnt like being clocked at 1.19? On aosp roms my phone works on 2.26 but on sense Roms i get terrible slow down on 1.19
What governor are you using? I recommend using the interactiveX governor, it's always been good with my phone. Make sure not to use screen on/screen off profiles with this governor though;)
I always use the smartass governor, its what I've always been told to use. I'll try interactive x if it still reboots Then ill scale it back. I appreciate the help :)
I'd say scale it back first. The rebooting is most likely a function of the phone not being able to handle that setting. The scaling options just dictate how fast/slow the CPU gets up to that setting and shouldnt cause bootloops by themselves
Give 1113 a try
