Root [Kernel][JB][SENSE] Arc-Reactor [3.4.10][S2W][linaro] [-O3][WIP]
ocnbrze
DON'T PANIC!!!!!!!!!
  • May 13, 2010
    40,630
    1
    33,830
    Los Angeles
    yay a new sense kernel!!!!!!!!
    again as always....not mine
    original thread:
    http://forum.xda-developers.com/showthread.php?t=2180815
    thicklizard said:
    I bring you a JB sense kernel based off the 3.16 OTA.
    What is a kernel?
    In computing, the kernel is the main component of most computer operating systems; it is a bridge between applications and the actual data processing done at the hardware level. The kernel's responsibilities include managing the system's resources (the communication between hardware and software components).
    Changelog rls 1 (3/7/13)
    update clocks to qualcom spec
    add usb fastcharge
    update topology drivers
    Make vfs_cache_pressure configurable
    mm: adjust vm ratios, vm_dirty_ratio from 20 to 10
    add 192 freq step
    boost l2 and fsb
    support for frandom number generator
    optimize slack
    add vr sio zen schedulers
    tweak deadline
    aio.c: Asynchronous I/O latency to a solid-state disk greatly increased
    set LOAD_FREQ to (4*HZ+61)
    increase readahead
    disable gentle fair sleepers
    lib/memcopy use glib version
    lib/string use glib version
    optimize slub
    allow pipe compiling
    vfp compile with neon
    add s2w
    all linaro O3 fix ups
    makefile options for 03 and buildflags for linaro
    fix compile errors for linaro 4.7.3
    Initial Import
    Things to do
    Mpdecidsion
    Thermal Management
    add more governors
    oc gpu
    add voltage control
    Instructions
    - MUST be s-off
    - Boot to recovery
    - Wipe cache
    - Flash zip
    BEST TECH IN 2023
    Smartphones
