reppard
Well here is an overclockable kernel for the optimus m that came with 2.2.1 stock. This allows you to change your cpus speed and has the potential to damage your phone if not used with common sense. That said, I AM NOT RESPONSIBLE IF YOU F UP YOUR PHONE! Every CPU chip is different so stable speeds will vary from phone to phone. My phone isn't stable above 787 MHz. That doesn't mean yours can't go higher
Download the zip to your sdcard.
Reboot into recovery.
Wipe your cache and dalvik cache.
Flash and reboot.
You will need setcpu or a similar program to change frequencies. I have to configure the gbrom so the cmod7 settings will have that ability. Hit the thanks button if this helps and the donate link if it really really helps
Big thanks to asadullah for organizing our mob on LG and making the source code possible!
Enjoy!
UPDATE:
This version works with any rom and wifi modules were compiled separately so wifi works right out of the box.
Lower set CPU Max Version, people with boot loops test this update
Max set to 729600(i can go lower if needed) and default governor is ondemand.
r.O.C.K-v0.3-AnyROM.zip
MD5 Sum: e5e905eb5fcd6a9e93a180c7e25c2b3d
In compliance with GPL, here is the source:
r.O.C.K-v0.3-Source
Battery Calibration install this and let your battery fully charge. The run the app, unplug the charger and calibrate. This should be done after flashing a new rom or kernel.
Flash and reboot.
Enjoy!
UPDATE:
r.O.C.K-v0.3-Source
ha ha first.
