shorty1993
Starting with I have searched for days (every site Google will find) with all keyword combinations possible & have learned a lot but not the answers I am looking for.
Issue is that I freeze at any speed over 604 max (via Setcpu). Tried setting higher speeds as a charge profile to see if being triggered would change yet didn't. I have done nothing with advanced menu as I have found nothing posted referencing it netting higher speeds. I am rooted, started with zanfur kernel, switched to a conap kernel (bfsv6), both with same results. Did dalvik wipe (i am running amon ra) then went back to zanfur kernel to try again, same results. What am I missing? If this is just equipment limit then what's the result of flashing a custom Rom with default clocks of 710+++? Thanks for any assistance, know this is long but wanted to get all the info out to be seen.
Thanks In advance
Thanks In advance
Let us know if its not.
...yeah, you probably need a replacement... Hope you get a good one. Best of luck!
