Root [KERNEL] Plague kernel for the Huawei Mercury M886/C8860
PlayfulGod
Extreme Android User
DISCLAIMER: This is a CUSTOM' ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
  • Developer: Playfulgod
  • Description: Custom kernel for the Huawei Mercury M886/C8860
  • Version: v1.0
Well folks, finally some goodies worth having for the Huawei Mercury. This is for Gingerbread!!!
Added Goodness
  • Overclocking up to 1.9Ghz
  • Interactive governor
  • Smartass2 governor
  • Lagfree governor
What doesn't work
  • cpu boots @1.9Ghz on first boot, but sticks after setting with a CPU app.
Requirements
  • Must be rooted
  • Will need a CPU Control app (ROM Toolbox & System Tuner are nice ones
How to install
  • Have drivers installed
  • Download & unzip file attached below
  • Installs same as cwm
  • boot phone into download mode (pink screen), from power off, hold volume +/- and power
  • Connect USB Cable
  • Open Nautilus with root privileges (have seen it posted that Windows Explorer works too, but I cannot confirm this)
  • Look for the partition with 252MB and has images & Music
  • Open images
  • drag and drop the unziped boot.img and ok to overwrite old one.
  • Pull battery, re-insert battery and boot as normal.
Downloads
Donations
Official Donate link if you like my work and would like to show your appreciation and support. All donations are greatly appreciated!!
