Root [KERNEL]SpeedDemon V5.6 (Performance & Battery Improvements) - MIUI Kernel
"Stupid Zombies" doesn't play right anymore after applying the kernel. It hangs and takes a few seconds sometimes in between shots for it to wakeup. Only game I've noticed this with though.
Try reinstalling if you already had it installed; you could also try uninstalling it if it's installed, wiping dalvik cache, reflashing Kernel, and then installing app. Apps likes to act wacky sometimes when things are changed while they are still installed...
Edit: Overnight charging is a little bit safer because of trickle charging; I for one don't give a crap about warnings and dangers, I charge overnight. :cool: Imma boss... but really, kids, don't try this(try to be to like me) at home, always listen to parents, warnings, danger signs, and strangers who try to put you in a car...
Poler, it probably will be included in a another kernel but not by me...
lmao nice warning
Haha OK then Mr. Boss. You should put that up as a warning on the first post :D
Well since gaming works better for MIUI now how well does HD games work with this kernel ? no one really answered this question :p
What if they have candy???:D
Whats the average ram usage?
like how much ram are you guys using say with a clock widget and letting the phone sit for a couple hours?
Anyone having problems with Incredicontrol? It's not saving any changes I make to the voltages, even when Apply on Boot is checked. I can set the voltages and see the "Preferences Set" notice but if I close the app then open it back up everything is back at default.
is this newest build built off the 1.11.25 11/30 build of miui that was just posted tonight(11/30...12/1 where i am right now), and if not will it break anything on the new build, or are you going to update it for the new build if it isn't?
it works with the latest build but it breaks native wifi tether (at least on my phone) unless you really need overclock i'd wait and see if Austrie updates the kernel to the newest build
ya that's what i was figuring that's why i thought i'd ask.
thanks
I'll update tomorrow...
awesome that's something to look forward to :)
EDIT: since the new miui build came out ive been on the stock miui kernel and i gotta say speeddemon increases battery life without it my phone died right after i got out of school when it usually last all day makes me more grateful of Austrie's work. Thanks dude!!! :)
