Root Keyboard color
I am currently using the Smart Keyboard Pro at my input method and I have my skin setting set to the iPhone one. Is there anyway to have one of selected skins (such as the iPhone), but change the color of it?
You just need to get a new skin. They come in every major color red blue purple you name. Unless you meant change the color of the iphone skin not sure there is something for that
This is the one I'm using. It can be found here:
Smart Keyboard Forum • View topic - GlossBlack skin
There's a few others in that actual forum though.
You just need to create a folder on your SD card called "skins" and download the zip folder in that skins folder.
good link yeah thats like one stop shopping for skp.
I still swype a lot and use swiftkey too. Im trying the GB keyboard out and its ok definitely better than android stock. But smart key pro certain is as good as anything else
It's all what you're used to. Been using smart keyboard pro since my first week and haven't looked at anything else since then lol
