Keyboard Issue
Kjgmusic
I have a very slight but annoying issue with my sliding keyboard. About one-fourth of the time, the "p" key does not register when I press it. It is the only key I have a problem with. I've only had the phone for a little over a month.
Do you think it's a hardware or software issue?
Any ideas as to how I could get it fixed without a hard reset or replacing the phone, if possible?
Worth taking to Verizon?
Thanks!
I have not really heard that issue before but sounds like something that is possible.......if you've had it for more than 30 days they will send you a certified like new which some people hate and others are fine with. To make you mad look how well my "p" works:pppppppppppp
I would get it replaced if I was you. If one key is bad already the rest will probably follow before too long
