stevenhippie
ok so here goed nothing,
hi i have a desire HD wich was running CM, and i wanted to flash : Blackout ICS Incredible v3.0.0 FULLY WORKING!!! [4.0.4][Sense 3.6]
i went to rom manager, went to recovery and wiped my cache and did a full wipe, then i went and flashed the new one...
With the new clockwork mod a menu appears, asking a bunch of stuff, i just went trough it and pressed next, it said it was done and i went ahead and rebooted, now here it comes... the HTC logo appears, and after that i just get a black screen, the backlight is still on but it just does nothing, i can't get into recovery with the power/vol down because my vol down is broken, and abd doesn't seem to work ! does anybody might be able to help me? i would be so thankfull !
-EDIT- oh and when i power my phone on right when the logo dissapears i hear something, a small crack, inside my phone , i don't know if this might be helpful or not but i'm trying to give as much info as possible..
FIXED ! i'll post how i did it in case if somebody has the same problem,
so i first got adb working on my pc then i placed another ROM in my sd to flash
i opened cmd and typed : adb reboot bootloader
my phone jumped on in bootloader, and from there i went to recovery and then just flashed another ROM, and now everything works !
but my vol down button is broken so i can't get in hboot, i might try to fix the button first
