SykkNyzz
Disclaimer: Blah blah blah, you know what you do is on you.
What is this?
Fixes of older ROMs made by whoshotjr2006
CM 11 [Don't Use as a Daily Driver]
SlimKat
OMNI-Rom
PAC-Rom
AOKP
Carbon
Wipe everything but External
Flash what else you need.
Gapps, lte files (not included in this ROM)
Gapps: http://www.opengapps.org
Direct Links for LTE files: Follow this link.
http://androidforums.com/threads/port-saber-pac-rom-4-4-4-lg-l90.991943/
(FREEDOM POP APN FIX!!!)
http://www.mediafire.com/file/mc1kipz9nugftbi/Freedompop+APNs+fix.zip
Credits to:
Tom1957 for the discovery.
whoshotjr2006 for the builds.
curtis1973 for the LTE zips.
mopedryder for the original LTE builds.
JoshD for the mirrors.
Download Links: (My Dropbox)
CM11-Volt-Remix (demonstration purposes only)
SlimKat-Remix
Omni-Volt-Remix
PAC-Remix
AOKP-Remix
Carbon-Remix
Mirrors: Thanks JoshD!
LG Volt Custom ROMs
(Once again up and running!)
The folder from latest CM11 CAF build (etc folder under system) that I used for all the remix builds:
https://www.dropbox.com/s/oibcc2k0nmymi1q/etc_from_CM11_CAF.7z?dl=0
I only wanted to make it easier to be found. I took the info that was laid before me by the people listed above. So I used this info to make these ROMs come back to life!
What works?
From what I can see, except Modded USB Tethering.
PDA NET, Clockworkmod Tether, or Easytether can somewhat fix that.
Works on Boost Mobile (I tested that)
Curtis1973 Confirmed that it works on Virgin Mobile as well
I'm not promoting this but this is what I used to fix writing permissions for ext SD after flashing any ROM
https://play.google.com/store/apps/details?id=in.co.pricealert.apps2sd
Dialer Code for AOSP ROMs:
*#*#4636#*#*
BTW I am not a developer, I do not understand everything about CyanogenMod.
So all are welcomed to take over this.
BTW any ROM I fix up will be Remixed here.
Thank you all for what you do...
SykkNyzz
What is this?
SlimKat
OMNI-Rom
PAC-Rom
AOKP
Carbon
Credits to:
SlimKat-Remix
Omni-Volt-Remix
PAC-Remix
AOKP-Remix
Carbon-Remix
LG Volt Custom ROMs
What works?
*#*#4636#*#*
SykkNyzz
