Root KitKat Remix Roms! CM 11, SlimKat, Omni, PAC, AOKP, & Carbon!
Ran into a wierd thing on SlimKat Remix rom. If I have phone powered off and insert recharging cord the display brings up the recharging big image of the battery but instead of showing charge state and remaining off the phone boots up to a locked state, then have to hold power button till it reboots to normal working state. I even tried plugging in charge cord while running normal and then powered down to OFF it goes right into this reboot all locked up again. Can anyone else see if theirs does this with SlimKat Remix ? I should be able to turn phone off and insert charge cord with just the battery screen showing up with battery charging motion and phone remains off. I got a feeling this is some kind of bug in the rom itself. So for now I can't turn the phone completely off and have it charge, has to be on.
thanks for any responses
Same thing happened to me (not on the remix just on regular slimkat) and a whole bunch of other people.
I know of this issue to happen if the ROM didn't have the mod set up for it. Back when I had a photon q. It would die and glitch when the power was off. Sorry I wish I could help. :^/
I haven't had that happen, but I get random reboots with certain Xposed modules and during updates of certain apps (no I didn't pay attention to which ones).
I Had That Issue So I Finished Going To Pac-Man Has Slim-Recents Wich I Like Alot And Alot Of Other feature I Do Get A Random Reboot Hear And Their But Is Pretty Stable And is a Good Daily Driver @kwiknuts
On the cm11 ROM my service comes and goes on its own. Some times it just says searching for service, which means no data or service. I flashed the APN fix but it didn't work. Any one have a suggestion?
Just installed SlimKat and root access is turned on, but it won't prompt me to give permission. Also, the built in system app remover doesn't work. O.o
Maybe go directly to the app? Idunno, i fixed older roms, but I'm on No Gapps Stock version.
I'm not a hundred percent sure but I think the way you get root working is to turn on developer settings. I used to use that ROM and I got root working (without SuperSU) but I don't remember exactly how. Try looking some more through settings if you can't find how in developer settings. Also the built in system app remover needs root so once you properly enable root in settings it will work great. If you can't figure it out yourself (getting root working without SuperSU), I can flash the ROM myself to figure out for you. Good luck
Am using Carbon Remix on Boostmobile Volt how do I do a PRL update? I ported in a new phone # using RingPlus but I don't see an update PRL option in settings. And none of their manual PRL instructions worked.
Only in stock. Basically backup everything, flash/restore stock, update prl, and restore backup.
Just curious but what does this do as far as PRL update from page 1:
Dialer Code for AOSP ROMs:
*#*#4636#*#*
If I just reflashed RingPlus APN fix would that update the PRL ?
*#*#4636#*#*
I just know that under AOSP DC phone settings... It shows you can switch connections ( example: auto prl) but I'm at a loss what I'm trying to accomplish there... But I guess I should look into that more... Sorry about that. Maybe backup, switch to stock, update prl there, then restore backup?
Think you have to flash supersu zip its not included in SlimKat.
It is in slimkat... You have to get developer options active as well
