Help Koodo 3g problems
Alright so i just unlockd my Telus Hero to work on koodo (telus network) i added 100MB of data to my plan and added the following to my APN
Which is directly from the koodo site....how ever my data is not working and in the network menu it says
Mobile Network Turning on....... and its greyed out with a check mark....
Can anyone help me ?
I have those exact same settings on my Samsung Captivate, data works however I am unable to send picture messages while data, phone and plain text messaging works!
I am stumped as to why
At a guess, you'll need to add "mms" (without the quotes) to the "APN type" entry.
Most networks require two APNs; one for MMS and another for all other data types. If you currently only have one, create a new one with duplicate settings but make the change detailed above.
