Help Lag in Text Messaging...
eshin
Does anyone else notice that when you click on the Text Messaging icon that your text messages lag as they appear in the display (for example, I see phone numbers first associated with each message, and then I have to wait a few seconds before names slowly pop up in place of each number)?
If so, is there a fix?
It may have something to do with the task killer? I cant say for sure, but I noticed that my phone started to run smoother after i removed the task killer app that i had installed.
You could be killing some sort of app in the background that keeps this type of thing running smoother, but thats just a guess. maybe you can try removing the TK and see if that helps.
this worked...thanks. task killer is pointless on anything besides a G1.
Yeah, I was kinda skeptical about removing the task killer at first, but after i did, i noticed that a lot of "hiccups" that my X was having before hand started to disappear. Glad I could help! :D
Bottom line: Task killers = bad IMO.
