Help larger icons for newer sgs2 firmware updates?
If its on the internet then it must be true!
I wouldnt worry too much about it anyway, as this update will only affect Samsung's TouchWiz. Just use Go Launcher. Its far superior.
it'll look like a big-print version for the old......
ironass will be straight in there.
Cheeky little blighter... it's half an hour on the Naughty Step for you! :D
Seriously, I use reading glasses and try and adapt my phone so that I can see it without having to put them on all the time...
Big HTC type clock and weather on Home screen helps as does my ROM, Dlev, which has a range of fonts and sizes that helps.
Perhaps you should consider trading your GS2 in for this model then butty:
Great idea lads! :D
Does the phone come with a larger screen and bigger buttons hawker?
The ear trumpet is ideal if they do it with A2DP and a ear hook Sydney99. :cool:
Seriously though, I had to request the modder for the Dlev ROM that I am using, to make me a couple of mod's. One was for a circle type battery that made it easier to see the charge left and the other was to revert to the stock Samsung dial pad as I couldn't quite make out the ROM's dial pad without glasses.
Mind you, my parents did warn me that I could go blind! :D
the circle battery and stock dialer are the 2 mods I installed right away!
Damn I must be getting old too!
I'm going to have a little play about with his base theme to revert some of the icons back to stock as there are a few I dont like (sms icon in particular)
is it gang up on ironass day then????
ironass - if you're feeling a bit got at:
Action on Elder Abuse - Homepage
Guys we better have a whip round some WD40 for ironass but bagsy I'm not applying it lol that's your job guys lol
I'm begining to think ironass is aka Dom Joly with his giant phone you certainly need an ass etc of iron to do Trigger Happy Tv
@hawker any single bridesmaids from wedding that would make a good housekeeper for ironass looks are not important
A few Richie, but none that have just escaped into the community and are visually impaired enough unfortunately!
:D
Guys let's chip in and get this for the old man for his xmas http://hearing-aid-ratings.blogspot.com/2008/01/bluetooth-capable-hearing-aids.html
