Hi i installed tims4e and now i cant connect to the internet through wirelesss or ethernet
Do i need to change something to make it work
wireless keeps connecting and disconecting
ethernet just doesnt connect
well what i do is reset my wifi router, and my tablet connects right away,.works everytime!!!Thanks for all the posts and firmwares so far - been insightful and gives me hope with my new tablet.(16GB model)
I had an issue with my CPU, where it was generally stuck on 100% making the tablet unusable. Since changing to 4e, that issue as gone. But now I'm unable to get wifi (unable to scan for networks) - I don't have a backup of my firmware that came with device.. I've gone through several of the firmwares, looking for one that works for me, and none do. So I'm back on 4e, without wifi.
Looking through posts about changing wpa_supplicant have all been ineffective for me. Looking through the LogViewer, it's stating "Cannot find driver rt2070sta in proc".
The driver in 4e appears to be rt2870sta (that's 8, not 0). I can't find any resource for 2070, nor an ability to repoint or try switching to 2870 in case it works..
Any ideas?
Thanks for all efforts so far!
install wallpaper picker and you good to go... get at marketMUTARI do you know if there is a way to install live wallpapers on the flytouch 3????
This is like the 7th time I have posted without getting info really....but does anyone have success with anything BLUETOOTH on their machine yet? Some drivers are there, but no one has shed any light on what they are used for, how to use them, or what they are configured to do and not do. Thanks anyone with knowledge on this!!
Regarding my issue, I'm pleased to say a fresh download of 4E solved it, and now my tablet is 100% working![]()
didnt understand very well...
are there two versions of tim 4E? 4e and 4E are different?
Do you mean that?
thanks
- Huawei 3G sticks support (Off by default, see tip) on main pageThis new firmware 5a supports mini modem huawei 1756 ?
I've used a 4 and 8 Gb Cards. Without success. I have the Build: FRF85B. They few threads about probs with this build.
