Help launcher help.????
1iwilly
on the sense rom how do i un install adw launcher so i can put on LauncherPro
when i go in to the settings applications manage applications running click on adw it doesn't have uninstall highlighted.????thanks
its located in the /system/app folder you can delete it out of there, or move it to /data/app
then it will do it.
then it will do it.
ok thanks or can install launcher pro the select it instead of adw in case i don't like it i can switch back to adw with no side effects .
You should definitely install lpp before you remove your default launcher or face blankness.
I have both...just set the preference to which one you want to use, you don't have to delete ADW and it's always there to play around with then if you get bored with the other one or you see a good theme you want to use
thanks that is what i did
