Help Launcher Pro Beta/Plus
irmac
Hey so I'm using the new launcher pro beta on my X and was wondering if I need to disable the stock launcher somehow so it'snot running in the background and eating resources?
TIY,
IRMAC
By the way, I highly recommend getting LauncherPro Plus while it's at $2.99 because he will raise the price. The benefits are that you'll be able to get exclusive widgets (he's bringing the mock HTC ones onto LPPlus).
Im still on the pre release softeware so it's not showing up for me in the market place. :(
Yes. Very nice indeed. Just downloaded it today. People widget is the only available widget now. Nice to see he is adding widgets. More widgets to come. Launch Pro rocks.
how do i switch back and forth between LP and the stock motorola one? I wanna see what I had on each screen so I can add them to LP
does anyone know how to switch back and fourth between stock and LP on the Droid X?
download: Home Switcher
yes...but if you press the home physical key..it will bring you back to LP. Id like to go back and forth on the launchers myself, but it seems you can't have LP installed and use the home key for motoblur
I just did, I agree - I love LP!
But my people widget does not have this popup
- does anyone elses? When clicking the contact it just takes me to their contact profile page.
Just curious in case I was doing something wrong.
