I recently downloaded the LP icons from the market because I wanted to change the default dock. I am having trouble setting the new docks I download. The only option I can find is to change the dock background and all that does is hide my new dock behind the default
If you use LauncherPro Icons, it creates folders called LauncherProDocks and LauncherProIcons on the sd card. These then show up as an option when you select "Custom icon". Maybe you could create these folders manually?I can't get any of the icons I d/l to show up in my gallery. I'm using dropbox and put each icon in the photos folder and they don't show up, only my jpegs do. Where do you put the icons so they show up?
