snoprosledneck
Member
So I switched from Sense to launcher pro for a few days and started taking a liking to it. Did a few custom things like changed my dock bar, few custom icons, blah blah blah. I did like friend stream on Sense and realized i couldnt get it on launcher pro unless you paid for the full version "launcher pro plus" or something like that. Any Who i talked myself into it for the calender Widget they offer and for the facebook "friend stream look alike" widget. I made the purchase and had a successful unlock. I went to my open page and put my calender into use and slid on over to my other open screen where i wanted to put my facebook widget. I open the widget and it shows up with a blank screen. It says "go to prefferances go to lp widgets, select facebook, go to facebook log in, enter correct info, and tada" (in a nutshell not word for word) so i put in my informantion it shows a loading screen, and once the loading screen goes away it shows a empty log in screen again.... so i put in the info again and the samething happens! I have tried this alot and cant figure it out so if someone could help i would appreciate it. BTW i sent a email to the DEV and havent gotten a reply. Thanks for your help!
