Help Launcher Pro Plus Facebook Widget problem
goblue42
Member
I am getting an error message on my Launcher Pro Plus re: Facebook. I keep getting a screen pop up saying Please add your Facebook credentials to LP. I don't use FB at all and dont even have a FB acct. How do I delete the FB widget from Launcher Pro Plus or stop this pop up?:mad:
Menu>Preferences>LP Widget Settings>Facebook Widget
Maybe try setting the update interval to manual. Just a guess. Mine is showing at 15 minutes and I don't use it LP's FB widget at all. That must be the default. Do you have the widget showing on one of your homescreens?
thanks but didn't help. Still getting the pop up. Pretty sad LP made a program that is this locked down with no way of fixing a problem like this. Any chance they will give me a refund??? LOL I know this is a shock to 90% of the folks....but I have NO use for Facebook at all. I have my Twitter and I'm good. Any help is much appreciated
It should only pop up if the Facebook widget is on one of your screens or info was input in those settings ...
Try clearing data and cache AFTER making sure you have the most recent version from the market. If that doesn't work try contacting the developer
Still no luck....even went to Launcher Pro forum and posted the same question with no response. I am amazed that an app this popular and this widely used has a problem like this with no fix. I wish I could just delete it and reload to start all over again...BUT....I have LP Plus so I would have to pay for it all over again. I have to get this fixed because I believe it is making my Evo run slow. ....very frustrating.
You're the only person in the world having this problem...
I know it's not what you want to do, but have you thought about making a fb account and logging into it in LPP to stop it?
You can use all fake info on the fb...
I know you managed to circunvent this by creating a FB fake account. But I was wondering if youn use the Friends Widget insted of the Twitter one.
