dumbmayhem
Ok I've been searching for the last hour and half and not quite found the answers I was looking for so apologies if this has been answered but I did look
Anyways, I've installed LauncherPro on my desire but looking for a little help with it. I was looking to change some of the icons as the bottom task bar(is that the dock that people talk about?). I tried holding down the icons I wanted to change and the phone does vibrate as if a menu should pop up but it doesnt so I was looking for some help on that one.
Second, I think I may have found the answer for this one in the last 5 minutes, but all of my widgets have more or less disappeared like latest sms, email etc. I was looking to have an email widget rather than an icon but I think I read that you can only get these in LauncherPro Plus. Can someone confirm that if possible?
I've also downloaded FolderDesigner to change some of my icons and have changed the gmail icon on my home screen. My problem is that in the big apps menu - it's still as standard in there. Is there a way to change that? I might have read I would have to root to it but again would like confirmation before I jump to conclusions.
Thanks
Thanks
