Root LCD Density ?
D
Deleted User
Guest
Im running rubix blurry 1.6.3 and just downloaded a lcd density changer and am having a problem.
If I change the build prob to anything other then 240 my dialer and contacts app from the home screen crash when I click on it and I loose signal temporarily...I tried using spare parts and used compatibility mode but nothing...some please help me fix this!
i found an app that will allow you to make calls and it acts like a contacts manager called Dialer One which is free i have my lcd set to 200 and with that app i can still dial out and look through my contacts
I was having TONS of problems with my phone a few weeks ago and I traced it back to LCD Density changer. It took a long time, but once I went back to 240 all my problems went away.
Now that I've done the update and everything seems to be working super smoothly I just went in probably 10 minutes ago and changed it back down to 200 again because I loved how it looked at that density. We'll see if it holds up.
I just ran into this also. The dialer hates a density other than 240...Down the app Dialer One...free in the market...Its even better than the stock dialer...Alot of options in the settings. And works on other density's..I run 220.
EDIT: Sorry Prevlin I didnt see you already advised him of the app
