What I meant was how do I stop/remove apps that are pre-installed on Droid, apps that like to start all by them selves and how to use the Superuser Permissions.
easiest way to remove apps from /system is with Titanium backup. In terms of using Superuser Permissions there is not much to learn. When a app requests root permissions you will get a popup and you can allow or deny it.
