K kstuffer Member Jul 16, 2010 #1 This will be my first major smartphone purchase. I wanted to know if hot weather could ruin the phone in terms of overheating and what not. I like to play a lot of sports outside so would there be an issue with the hot sun beating on this bad boy.
N NNN Member Jul 16, 2010 #2 kstuffer said: This will be my first major smartphone purchase. I wanted to know if hot weather could ruin the phone in terms of overheating and what not. I like to play a lot of sports outside so would there be an issue with the hot sun beating on this bad boy. Click to expand... Hey how ya doing! Let me tell you what I know. Heat is the worst thing for a battery. When subjecting your phone to prolonged episodes of heat, it's going to lose it's life very quickly. So while the hardware of a phone won't be affected much by heat, your battery will get worse and worse over time. Naturally, batteries get worse over time as you cycle them, but heat, especially over 100 degrees, speeds up the process almost exponentially. Just make sure you buy a secondary battery when you notice the battery life starts getting worse. Hope that helps!
N NKT Android Expert Jul 16, 2010 #3 I know some devices have sensors that will shutdown the device if it get's too hot (LG Envy Touch)
Vihzel Destroying Balls Everyday Jul 16, 2010 #4 Do NOT leave it out in direct sunlight. It will basically make the phone into an oven.
trophynuts Extreme Android User Jul 16, 2010 #5 Yeah i wouldn't recommend direct sunlight either...for any ped as far as that goes.
