Help LED blinking and no response
dhays90
I was talking on my phone and surfing the internet at the same time and all of a sudden my phone just shut off and the LED was just blinking. I had my phone plugged in at the time. I unplugged the phone and it quit blinking but the phone would not power on. Earlier that morning 2.2 was installed. What is my phone doing?
Overheat most definitely. Take the battery out and let it sit for 5 minutes, then you should be able to put it back in and use it normally again. Most likely talking + wifi + charging + heat from your hand/face = overheat.
Was it amber/green flashing? Sounds like overheated.
Amber. It was over heating. The battery was extremely hot and my backside of case was. Cool now i know. Thanks :D
