Does anyone know of a way to get the LED notification light to blink in more rapid successions? The default is like 10 seconds between blinks and it drives me nuts...any suggestions (that don't require rooting) would be appreciated.
Lightflow works great for me. I had the same problem because of the settings too. For example if I received a text and swiped it clear from the notification bar, the light would still flash because I hadn't opened the message. You can easily change that through the settings though. GL.
Light flow is the best, it also allows you to use up to thousands of different colors for different programs. For example you can make the light hot pink for when your girlfriend texts or called you. one of the best apps of all time
Just know that light flow runs constantly in the background on your phone. I found it to be keep my processor fairly busy. I don't think its a problem, I just didn't need it. I wish google would just make the stock light more customizeable.
