Help LED Notification
Looking for an app that actually works with the Ally
I have tried at least 5 with no luck
This is my first day with the Ally and so far this is the only disappointment but for me might be a deal breaker as I use the color notification on my droid and miss it already
thanks for the help
tried blink, lightflow, dg alert, etc
so if anyone uses one that works I will be eternally grateful ;-)
You tried Blink? Strange. It works for me. I just hope one day some dev(maybe on here) can make an app or tweak that makes the LED flash like all the colors while someones calling. That would be legit.
Going to try both again- when I did a test the LED stayed an odd rainbow of sorts color
Ok trying blink now- got it to show color but it doesn't stay lit so what is the point? text message will pop up then when screen goes dark it will blink once and that is it?
is that how it works for you?
You can change the color, but it just blinks every once in a little bit and only when the screen is off, except when its charging. No way around it. Just cant change it on the ally.
