Help Led notification
Gareatron
Right now I'm using light flow but it doesn't always work. Sometimes it shows the led sometimes it doesn't. Is there another led app that works?
Lightflow is really the best out there. There are other apps like Blink etc but none perform like Lightflow. Are you on stock 4.2.1 or a custom rom?
Also feel free to email the dev Andrew. Great guy! I've worked with him in the past on issues and he's always awesome to deal with. :)
Yeah I'm on stock android i don't think I'll be rooting anytime soon. You're right about the other apps they don't work at all. Light flow only one that does work.
I'm using Lightflow and it works perfectly. I'm running a rooted stock ROM. Did you try uninstalling/reinstalling the app?
It works pretty well for me, not all apps are supported so watch out for that. Also ensure you set individual apps notifications settings up of you haven't already.
Same here, stock rooted and it has worked great for me. Just set up each app in light flow the way you would like the notification to work. Sounds and LED working fine for the apps I am using.
Can light flow change notification color for separate contacts?
I contacted the developer about this. No, it can't - but it used to have this ability. Google made a change that prevents it. As a workaround he has made it possible to have different labels have different colors (this may be paid version only, I'm not sure.) I haven't played with it but in theory, if you have a label applied automatically to an incoming message, you can have a different color for those. I'll set a couple up to test...
EDIT: I couldn't get this working. The feature is there, but I can only get the inbox notification color to display.
I have my wife set up as a contact in LightFlow Pro with missed calls, sms, and email set to pink.
I'm sure it worked last time I noticed...
You have a contact+ (picture of a head) icon at the top of LightFlow in Notifications...
I'll confirm this, I do the exact same thing (but with white).
