Help Lg bricked!
After trying to update to the Gingerbread mod for my LG GT540 using CM7 and using KDZ to install fastboot my phone has now bricked after crashing in download mode. Will not turn on at all! I guess there is nothing I can do at all apart from send it for repair? Any advice would be great and also any advice on best repairers in UK!
Thanks.
I think your best bet is sending it to LG, but bricks arent usually covered under warrenty because they are usually because a custom ROM failed to install, but you can always try to say you were attempting to update to 2.1 using the LG updater, if they buy it they should cover it under warrenty.
