mmmm idk what to do am i like totally f'up!?
can you helpp,,?
and then,,?
Highlight backup and restore then hit power you will get another list highlight restore push power then find your backup and restore
if you are a big esteem user and love the phone you will be amazed with this forum .. i would hang around here and see all the more you can do with your handset.
all i see is -back up -restore -advance restore -back up internal sd card -restore internal sd advancde restore?
idk? everything is deleted i think?
then download a romidk? everything is deleted i think?
You need to put a rom on your sd card and flash it. Sounds like you wiped everything off the phone
whaaaat?!!!
can you show me the way?
will i still be rooted
ok so where will i get a ROM?
i do not have a sd card reader i do have a pc an memory slot tho.. not for my little chip tho?
