I took my metro Esteem to cricket, they flashed it, now it won't support picture text or mobile internet, they handed my phone back with the new cricket number, text and talk only and said it could not be corrected. Is this a fact?![]()
Why would you go to Cricket over Metro?
Your prolly not going to get everything working. They should have told you this before flashing.
Metro says the same thing about phones they flash, but with apps like QPST you can put the proper settings in and everything will work.
4g wont as Cricket doesnt have 4g and you cant change out the uiic card in the esteem even if they didMetro says the same thing about phones they flash, but with apps like QPST you can put the proper settings in and everything will work.
4g wont as Cricket doesnt have 4g and you cant change out the uiic card in the esteem even if they did![]()
