Root lg esteem stuck
Hello and welcome aboard.
Sorry to hear that you're having problems with your phone, hopefully the folks over the Esteem root Forum might be able to assist you.
Thread moved.
Im guessing your rooted? Have you installed Clockwork previously? Im not understanding what you mean exactly.
If you can get a file onto the phone somehow, flash exitrecovery.zip. If you can't you have to reflash stock and re-root.. the only way i know of is to downgrade to zvb using the guide a then upgrade to zvd using the mobilesupport tool. Then re-root and you'll be good. I was already in your situation lol. ALWAYS keep exitrecovery and a rom or two on your sd card, it can save you from hella lotta trouble
my phone is stuck i dont know what to do... i think i deleted the recovery files is there anyway to get them back? my phone wont recognize as a mass storage its totally screwed? i need help bad
My phone is stuck at the same place. I try to reboot android and it just goes back to the RZR screen. I cant do anything with my phone. Please help me. Have you found a solution yet?
my lg esteem is stuck in recovery screen and there is no recovery file what do i do my phone is unusable help me please:confused:
I use CWM so I don't know if you have the option to install zip from external sd. if you do. put the file on the sd using your computer. if you have an old cpu with no sd reader, get a USB Reader/writer (One that can ALSO R/W SIMS would be great, put it directly on the internal sim"SD")......
if you get it going somehow use ClockWorkMod recovery instead
