Eddy120876
ok here is the low down on the VIDEO for the LG ESTEEM.
has very nice frames, on youtube its not 720 couse they are uploading video straight from the phone and it only uploads at the LOWEST SETTING! whitch is qcif 176x144
you have to upload 720 video from the phone thrugh the computer!
now the thing about all the video on the phone from qcif to hd is that there is some kind of DELAY IN THE VIDEO AND AUDIO. it does not sync all the way or something. ill post videos of my test. you can try this on your phone, record a video of yourself slaping or hitting your chest. it will be very easy to see that you hear the slap just a split second AFTER you see it in the video! now its easy to resynce latter in video editing software but, im trying to figure out how to fix the sync problem!
thats the problem with the video! and if it looks ''choppy'' you need to make shure your micro sd card is a class 6 or better. i have a class 10 in mine and its better than the built in card on the phone!
Thanks for the info Flowmaster
