Lg GT540 android 2.3.5 network problem???
Helo i update my lg from 2.1 to 2.3.5 v7 version and it works just fine.. But i have this problem that i cant connect to mobile net i set net configs and everithing but it just wont connect i enabled data and i downloaded mobile data on/off and it says "this funkcionality will not work on 2.3.3 or higher".. That is one problem another is that i cant download flash player 10.3 it says that my device dont suport it i find out that 10,1 can be suported but i cant find it... Sry on my english and thank you...
U have to download flash player from
a different site!!
U can't download it from the market as
it doesn't support our phones!!!
I don't think it will even work!! :):)
in my gt540 after upgad 2.3.3 to 2.3.5 my wifi is not working plzz tell me how can i solve this problame and also some network problame occued... plz gee me help
Ok simple things first, maybe a little too simple but the need to be ruled out.
1. Is your wifi switched on?
2. Are you sure your settings are right? ensure the security key is right and you are using the right security, it can be easy to hit WPA insaid of WPA2 and vice versa.
Also what is the network problem, its a little too vague for us to help you.
if u want to solve to problem download logcat from market and run it ...then switch on wifi and save the logcat and post it here...we can know why it is not working...
I had same problem, I even though that would be without net too, but was just a matter of configure the APN and ,"boom" working again.
