Bionic Chronic
So I am making this thread for those who would like to point out oddities that happen with their device. This means things that happen Out of the Blue, or without Warning. Things that are not caused by something you have done like Issues with a new ROM or Installing a new App etc. Basically not for questions about things pertaining to Root or CWM as well.
__________________________________________________________________________
Now here are a couple of strange things that happened to me..
A couple days ago I was texting a friend. Well i decided to grab lunch and so I hit the lock button and went to get food. I get a text from the same friend while I was out and it showed just the number not her name instead. I looked at my phone and realized My Contacts List was empty as was my Call Log and Favorite's. I ended up having to Re-Sync my Contacts list and reboot to get them back (EDIT: I also noticed all my saved Contact Ringtones reverted back to default). The second thing was today. I had been using my phone and noticed my battery was low. I plug it in and the battery Icon indicated it was charging so I put it down thought nothing of it. I look a little later and my battery was even lower.. I am not sure why, but it was not charging. I then unplugged my phone rebooted and plugged it back into the charger, and now it is charging again.
Anyone else ever experience anything similar? Thanks in advanced!
Of course, I didn't have GPS, BT, or Wifi enabled, just the normal 3G and what cell radio needed for calls. Finally got back the 3-4% I can never seem to get on a full charge.
