LG Motion in Boston?
daydreamingby
I'm planning on moving to Boston from Florida and wanted to know if any Boston users had some info about coverage, call quality and drops, and internet speed over there?
I'm in Boca Raton, and the coverage here is REALLY good compared to 3 years ago. I get good quality calls and no drops whatsoever here and around the cities north and south of here, and a solid 6MBps on 4GLTE, however I turn off $G to save battery and only use 3G because it has improved SO much that is good enough for youtube, and using Tunein Radio Pro or Pandora all day long on it.
I live about 30 miles south of Boston, and travel to Boston frequently. I can attest to the fact that the further you get from Boston the service is spotty (most people don't realize that MA is very rural outside of the hustle and bustle of the Boston/Brockton/Taunton/Worcester areas). The cell service in and around Boston is amazing, very fast, barely ever drops any calls or lags or anything like that. If you are going to be living in Boston specifically, you will be impressed with the speeds and coverage.
Here is the MetroPCS coverage map for the Boston area
Can I get a speedtest you guys up there have a weird spectrum setup
Unfortunately I'm on Connecticut in vacation but I'll do it up as soon as I get back. Here is franklin MA, thirty miles south west of Boston
Your moving to where metro supports BYOD (bring your own device). If you want to, you could go into a metro corp store with a GSM phone (must be unlocked already) and have it put on Metro's GSM network which uses T-Mobile's network. You can also buy a GSM phone at the store, I recommend the L9 since the bootloader can be unlocked and BobZhome is working on ROMs for it (he's also from Boston ;) ) The L9 also has xda support for the T-Mobile variant, but a handful of people there flashed the MetroPCS firmware on it, xda may also support the MetroPCS version sooner or later. I'm sure tmobiles coverage is better than metro's :)
Really good information from all of you guys!!!
I was thinking of reviving an old iPhone 3GS to Metro, but I would rather take advantage of the Motion 4G speeds from Metro since their speeds have improved greatly since 2011...
However, they have improved their speeds so much here in Florida, that I disabled 4G on my motion and only use 3G all day for Pandora, Tunein Radio, and light Youtube usage.
The reason I did that was mainly because of saving the battery, and because I was well enough on their 3G, which is nice :)
PS: I'll try and see if I get the same 3G speeds I get here there, and also if the antenna on that old iPhone 3GS is good enough for their 3G.
iPhone should work fine with Metros BYOD program as I've seen many iPhone 3GS's on T-Mobile.
